My LED turn signals
I was in my local Auto Zone this weekend and came across these side marker lights that mount on the side of your car. I thought I bet these would make some turn signals so after mounting and installing a couple of 20watt 5 ohm resistors I have some turn signals for $22.
They are Pilot and they come with sticky back that you peel off the protective covering and stick where you want it. They are advertised as side marker lights.
. . . they come with sticky back that you peel off the protective covering and stick where you want it. . .
I was afraid you'd say that. Between vibration and heat, I don't think that they would last long for me unless they were secured better. I might have to go investigate LED marker lights, and see if I can find some that mount with screws, or see if they can be adapted. Thanks for the info.
hay man thay look real good i got a set from parts canada not the same as your but thay look good on your bike just the same
