Jetting Done, Woo Hoo, now rough idle
Greetings guys
I have a Dec 2008 DRZ400 SM.
I have removed the pair valve and solenoid.
Used the JD kit for jetting (BSR) with extended Kientech fuels crew (Thank you Rudolph)
I used the standard settings the South African guys use:
150 main jet
jd blue needle
clip 3
stock 22.5 pilot jet
2.75 turns fuel screw (too much???)
3x3 and standard exhaust.
Man what a difference.
Only problem now is the idling is a little rough.
Tried the warm engine, lower engine revs until just idling, turned fuel screw over 3 turns, no change.
A little more and the engine died. Dont know if this was the fuel screw or just the lumpy idling ,
Im thinking I missed something along the way.
Thank you
Manfred
