Rotella T syn or Dino?
I have a 06 450 and after reading the success of rotella on this forum I decided to run it in my bike. I don't race the bike mostly off road/trail ride. My question is which is better syn or dino? Does both work well with this engine/tran?
They both work very good, I dont think you will be able to tell the difference, Ive personally only ran the regular rotella.
I run the 15W40 dino with great results and zero clutch issues. If you change it often, either is fine. If I were racing often I would probably feel more comfortable running the syn version. They are both very good oils and easy on your wallet. I've seen top ends that ran 120+ hours on Rotella dino and they were impeccably clean and the piston surprisingly still in spec. Highly recommended oil.
