Which RAM mount for te450 stock mirror holder?
I'm having a hard time finding which RAM mount to use that will screw into my stock mirror holder (2007 te450).
Can anyone help confirm which one I should be ordering? I was thinking of this part:
http://products.ram-mount.com/rammount/productdetail.aspx?partnumber=RAM-B-349U
( RAM-B-349U RAM BASE W/ M10 X 1.25 PITCH & 1" BALL )
But just wanted to be sure before placing the order... it would suck waiting a few weeks for it to arrive just to find out it's the wrong size!
Thanks for any help you can provide!
-Xhum
If anyone needs this info in the future, just thought I would update this post - I have confirmed that M10 bolts with 1.25 pitch threads screw into the 2007 te450 stock mirror holders.
I ended up using a mount slightly different than the ball posted above... here's my setup:
I used a ball mounted to a short piece of metal (part # RAM-B-252) that gives me a little more mounting leeway - I thought the ball coming straight out from the mirror holder might get in the way of cables. A 2 cm M10x1.25 bolt from the hardware store attaches the swivel-ball to my mirror holder. From there a ball-to-ball arm connects to a water-proof Aqua Box that I can use to hold either my car GPS or my nokia pocket PC that uses satellite imagery for off-road GPS uses.
The great thing about it is that you can leave the swivel-ball connected to your bike permenantly, and remove/connect the rest of the stuff in seconds. I don't normally need GPS for most activities, but it sure comes in handy during adventure rallys where they give you the GPS route prior to the run.
