Mikuni TM40 on 650L
Hello, just bought mikuni tm40 for my 650L. Has anyone tried one on this engine? I would be intrested in what jet sizes to start with! The bike has kn filter, bigger exhaust hotcams stage 1 and wiseco(compression promised 10,5:1 but I think more like 9:1).
I have a TM40 for my XR600 that's set up for a Hardly Skirtster 1200. I have a Sudco manual with all sorts of jetting and schematics and whatnot. I'll send you a PM with whatever you need.
"O"
"O"
What jets are you using then?
I'm using a TM40 on my 650l. Overall I happy with it's performance, but I'm still fine tuning the jetting. I can't remember off hand what main I'm running but I have a #12.5 pilot installed and the clip on the third position from the top of the needle. It's still a bit rich on the idle circuit, but tolerable (worlds better than wen I got it). Like I said overall it runs well.
I have whatever it came with. The PO said:
Pilot: 20, 22.5, 25, 27.5
Main: 135, 137.5, 140
Air jet: 1.2, 1.3
Needle jet: Y-4
Needle: 9DHJ-1, 9DOJ-1, 9OJY-1
These are baselines. I'm not 100% sure it's accurate.
"O"
I can tell you right now those supplied pilot jets are way too rich. I had to go all the way down to a 12.5 before it would idle right.
I have 25 / 137,5 now and it's quite good. I dont have the accelerator pump used for now.. It's good to rev it up on first gear and put to second with full throttle. But if I dont rev it as much and put in second and full throttle it goes to the lean side. So, with the pump the high rpm accelerations suffer? Maby I just had it too much set..
How about you guys, how's your pump setup?
Are you using Mikunis own jets or somethin else? Those should be proper mikuni jet sizes.
Air jet: 1.2, 1.3
Needle jet: Y-4
"O"
Good info! I'm going to order some air jets, needle jet and needles to try difrent setups. But install comes after the JE 11:1 piston next winter..
