86 XR600 master cylinder on a 86 XL600R?
The lower lever mount ear on my front brake master cylinder broke off. Called the dealer and was told that the master cylinder is no longer available from honda. I found a used master cylinder for an 1986 XR600. I looks like from the picture that it will physically bolt up to my 1986 XL600R. Will this work correctly on my bike? Are they the same part #? Thanks
It will work fine, but it does not have the brake light switch built in. If you want the brake light you could go with one of the hydraulic switches that thread in to replace the banjo bolt.
