Locked up cr250?
i have a 98 cr250 that is locked up.
does anyone know what this could be?
it happened when i was riding.
i was thinking it could be a locked up or seized crank bearing?
Thanks
Any visible leaks or damage? A little more info about what exactly happened will help others help you....:)
Did it make a really loud metallic squeek/squeal before it locked up? That would be crank bearing.
Pull off the cylinder, take a look at the piston, you should be able to tell if thats what the problem is. If not, try pushing the kick start down with the cylinder off. If its still locked or difficult to push, the problem lies in the Bottom end.
