Brake Help!!!!!
here is the issue. i drained all the fluid out of my rear brake line (04 crf250r) and i have fluid coming out of the bleeder valve but i am have problems gaining pressure in the line. so ultimately i have no back brake. Any thoughts would help.
You need a vaccumn pump. $25-$35 dollars and you'll swear by it. It works the best. Contrary to what you hear, don't waste your time trying to bleed them.
still have air in your system.. best to have someone help you.. press the brake, hold it, open bleeder until air/fluid stops coming out, tighten bleeder, let go of the brake.. repeat several times until even the snallest bubbles stop coming out.. also lightly tap the master to release any bubbles that may have gotten caught..
