Coolant Leak!?!
There is a small hole (1/8" diameter) in the case behind the water pump that has always been there but after a new top end (not the first) it now drips coolant at a pretty constant stream. its a 2001 yz125. Ideas??:)
Absolutely!
The hole is a weep hole designed to bypass the coolant if the oil seals fail.
It's better to shoot it at the ground than into the crankcase.
I replaced mine last year in my 03 YZ250.
The oil seals were bad, but mine also had scoring on the impeller shaft.
I replaced the shaft and the 2 seals.
By the way.. my shop manual shows the seals as the same part, but in fact they are 2 different sizes with different part numbers.
Keep that in mind when replacing yours.
