Needle differences?
I have a NOZI stock needle for my 300mxc, would there be improvements in power etc if i changed simply to another type of needle? like the red or blue from jd?
anywhere i might b able to go to read specifics about different needles? how they have power etc
What do you not like about the NOZI needle?
I do not like JD needles, they are too bland, I actually preffer the NOZx series over them.
i am curious if they will give me a different power response, or when the pipe hits. or itl give me more low/top end or feel that way..
i am doin fine with my NOZI but its the only needle ive ever had..
I feel the straight taper needles are bland and JD still gives some hit. The stock ones are too rich and weak off the bottom and then surge into the mid-range, too much hit and wheel spin. The JD is smoother, and the straight tapers are smoother yet.
JD sells a spread sheet that gives needles in comparison to each other.
