rmx 250
hi i just bought i new needle and seat for my rmx 250 2000 model then i put it all back together and when u turn the petrol on petrol started poring out of the over flow valves can anyone help thanks
I would start inside the carb. Check to make sure the float needle and floats were installed properly and then set/check the float height.
Good luck:thumbsup:
Check you didn't break the overflow tube off that is attached inside the float bowl aswell. I bought a carb that had this broken, same thing happened, turn the fuel on and it leaked straight out.
thanks it stopped doing it constantly, but now when i ride it then i stop and turn it off then a bit of petrol comes out
