Setting the sag
I going to do a longer ride thru the desert (135 miles) and need to use a larger tank (4 gallons) to be able to cover the milage. My question is, do I set the sag with a full tank of gas, half tank, or empty? Since that much fuel accounts for over 25 pounds, I'm confused which way to go. What do you suggest?
How often do you bottom out?
Personally, I would set the sag with a full or almost full tank, because to much sag and too much weight is a bad combo. I ride better with my sag at 90, than 105, that's just my opinion and I am NOT a desert rider.
good luck
Personally, if I were running in the desert, I might set it empty. That way with the heavier load it'll sack the bike out a bit in the back and help the bike stay more stable. Less rake, a little less weight on the front of the bike should help more than having it get twitchy as the bike gets lighter.
