speedo sensor
has any one had problems with breaking the small ears off on the speedo sensor in the front wheel. I have had two of them shear the ears off with no real reason. What could be causing this?? Any info would be much app.
Im pretty sure the wheel was on correctly, speedo flange on top of pinch bolts and hub fit on flush. I even looked at the manual and both looked the same. I know that the wheel was tight.
I remember reading on here once where a guy didn't line everything up just right when re-installing his front wheel and he broke them.
You have to have those two tabs lined up just right.
How did you put the wheel on? There is a nice procedure to do it right so the suspension works right and possibly keeps you from breaking the tabs off.
