adjusting valves with a hot cam
what are the valve clearences with a hot cam in it, are they the same as stock
After market cams have their own clearance settings that may be different than stock. I would check the existing clearance and compare them to factory specs before making a decision about changing. But in the absence of specs factory clearances would probably work.
