problems with clutch 1985 cr125r
when you engage the clutch it closes up fine, but hard to pull.
when you release it, it does not won't to release and takes it a
seconds to come back out so the bike will move. any suggestions?
start with the clutch cable . get some lube in it and see if it improves . if it dosent help it , youll have to start looking at the actuator mechanism .start with the clutch lever at the engine and work your way in . the lever may have worn the hole in a eggshape from years of use and dirt and junk will gather in the hole and make it slow to return. good luck!!
