Spark Plug Wrench
Hey there everyone I have a question on a spark plug wrench. What size spark plug wrench do I need to take a spark plug out of my 2008 kxf 450? Is there a special size or is it the normal 13/16''? Thanks!
Im not sure waht size it is, but these bikes use just a little guy spark plug. Your bike should have came with a special spark plug wrench...
Best you can do if you dont have one is get a deepwell socket on a extension and just keep trying, but I can assure you its much smaller than 13/16.
The bike does come with a cheap plug wrench that works well. Lacking that look for either a 5/8 or 16mm plug wrench on an extension. :)
CR
Best if you have a 5/8 spark plug socket that has rubber insert so the plug will
not drop out when you pull the soccket out and it is a 5/8. that or sometimes you can use a piece of rubber hose to go over the end of the plug to extract and install.
