crf450x idle problems help
2006 crf450xbike stalls when i slow down outherwise seems to run fine.tried adjusting idle under 2000 rpm it slows down and dies.idle at 2100 it jumps up to 3000 sometimes and then back down. it use to idle great at 1600-1700rpm. compression is 90 lbs.what should the compression be??bike has 6000miles and 200 hrs on it with just basic maintenance any help would be gratefull. any clue what is wrong.thanks
Sounds like a dirty pilot jet. remove float bowl, check for debris.
Gently remove pilot jet, and inspect into the light for clogs. Clean and replace. If lots of debris in float bowl, you may need to remove carb and clean more completely.
- or, you needle hold-down screw could be loose
