Opinions as to which Main Jet to try with my JD: #160,#162, or #165
I was able to pick up a red 'high altitude' JD needle from a TT member(thanks btw)... and now I am trying to decide which Main Jet to install for my setup. I would hope to only have to try one.
Here are the main jet options I need to choose from: #160, #162, and #165
Current Bike Specs:
I ride a 2001 DRZ-400E.
Snorkel Removed
Stock Pilot Jet
Kientech Fuel Screw
White Bros E-Series slip on muffler without the quiet core
I live in Utah at 4500 ft and ride from 4500 - 9000 mostly.
The JD instructions suggest with the Red Needle "Install the #160 Main jet for riding for riding 6000ft to 9000ft elevation AND use the RED marked needle in the middle clip position (#4)"
There is another note on the JD instructions "A 165 Main jet is provided for more open exhaust and any other airbox modifications"
So I am somewhere between 160 - 165. but it seems the clip position stays the 4th
I would hope Eddie chimes in... but I am open to people who have dealt with a similar setup in the similar altitude.
I have originally planned on the #160 Main... since the White Bros E-series slip on isnt too much of an open exhaust with its baffle system.
150 main jet.
Not to question your expertise, but more to help educate me on jetting, why did you choose the 150... I think the instructions even suggest a 155 for riding over 9000 with the clip in 3rd position. Please dont take offense... I just like to know the reasonings behind things.
becuase you need to have a 10% leaner main jet for your altitude.
keep in mind i tune bikes for a living at high altitude.
but as usual,do what you feel is best.
I feel best with your suggestions Eddie... I just sometimes like a little reasoning so I can get a little education myself. Thanks for your reply.
I hope to have this done by next weekend. I'll post up my results when I do.
My bike/carb specs should then be:
2001 DRZ-400E
typically riding 4500 - 9000ft
Airbox Snorkel Removed
150 Main Jet
stock Pilot Jet
JD Red Needle 4th clip (middle position)
Kientech fuel screw 2.5 turns
White Bros E series Slip on muffler
