klx 400r jetting specs for ssw/mrd mod pipe
Please excuse if posted already, been looking for 2 days. Could someone please post exact jetting required.
I have the jd kit with keintech extended fuel screw, 3x3 mod done, stock motor, ride at sea level to 1,500 ft. Thanks in advance, Scott
FCR carb, and I am gonna run stock fuel screw, Keintech extended fuel screw did not fit the carb for some reason. I opened up hole in bowel to fit extended screw but it would only thread in maybe 1 1/2 turns. Ordered it from TT store. Thanks, for your response Eddie.
with your ssw/mrd mod pipe. thanks, scott
2003 klx 400r (e model drz)
fcr carb
jd jet kit
stock fuel screw (keintech did not thread into carb)
snorkel removed (3x3 mod)
stock motor
sea level elevation
ssw/mrd mod pipe (awaiting delivery)
right now it is jetted as follows:
65 jet
stock pilot
blue needle 4th clip
2 turns out on stock fuel screw
are these settings good with stock pipe now and when I install the ssw/mrd pipe?
No problem, you are a busy man, yes 165 main, missed the 1. thank you for taking the time to answer my question. Consider this post closed.
