small stress crack on rim should I replace?
I just noticed a small stress crack on the outside of my front rim, should I replace it emediatly or is it ok for a while?
Locations and severity would play a role n my decision. I wouldn't ride on it too long though. A broken rim could cause some serious personal injury.
It is on the outside lip of the rim about 1/4" long. and bearly even noticeable but I was changing a tire and noticed it. I am at work so I cant get pics right now
When you say on the outside lip of the rim, do you mean up on top near the tire/bead or on the side of the rim? If it was in a place that had potential to split open wider due to constant impact I would consider replacement before it gets bigger.
I'd really need to see a picture though.
Dude, The last thing you want is that rim to unravel at high speed. get a new one ASAP!
this is common. I would ride it if I had something planned. Then i would have it welded or replaced.
I was wondering if I could get it welded actually. It is like just a hairline type crack but does go all the way through. It is on the vertical part of the rim that the tire bead is behind.
If it's all the way through I would consider replacement. Why take a chance with getting way frickin hurt for a couple hundred dollar part? Not worth the chance IMO.
RRIIIIGHT>>>>>>>>a wobble. Its a dirt bike, you cant feel the wobble that this MAY cause. I would weld it and if it cracks again then replace it.
I think I am with you on this one, A wobble that you would notice on a Dirtbike W/ Knobies offroad, I certianly am not riding 100mph and on asphalt. Most of the trails I ride I am lucky to see 30 but anyway, I found a good front wheel on E-bay so hopefully I will win that one and get this one welded as a back up
i wouldnt weld it... most people cant weld alloy very well and it may cause the rim to have soft spot that could rebreak or colapse on a hard landing. its cheap part to replace and isnt worth risking injuring yourself over it.
