Brake bleeding
Guys, I'm desperate. I spent 2 hours trying to bleed the front brakes on my 97 KX 250. They worked fine but last week I took the hose off to one end and I just figured I would have to bleed and be good to go. I even bought one of those bleeding tools with compressed air and that won't work. What tricks do you guys have for brake bleeding? Thanks.
if you took the hose off, have you emptied the system of fluid? if so the best way to do it is buy a large syringe, with a pipe off it that will connect onto the bleed nipple, get a friend to puor fluid into the master cylinder, while you use the syringe to draw it through, this seems to be the quickest way i found, then when fluid comes through, bleed the system as normal so you expell all the air!
