Quick Question
air pressure builds up in your forks, can blow seals and affect performance. Air has different qualities as it heats and cools, makes for a variable. Variables are bad :)
I bleed mine before every ride, if I remember...
Hope that helps
Thanks. So should i bleed them before i tie my bike down, or before i actually hit the track?
Bleed before you hit the track.
I place my bike on a stand with the front wheel elevated off the ground and then loosen the bleed screws at the top of the fork. Tighten the screws up and ride, ride, ride.
