94 CR250 Cases
I'm ready to mate the case halves together, I have the center case gasket in place + that little o-ring. Would it be a bad idea to use some type of yamabond or similar sealant too (I know they only use sealant for a gasket on some makes) or would it just be for extra sealing security? My manual mentions nothing of it.
1. Gasket + sealant (I like this idea the best)
2. Gasket
3. Sealant only
What do you guys think?
Definitely use the gasket at minimum. I've used a gasket and a little honda bond and that works good too. Just put a little on both of the case halves with the gasket in between, it should seal real well.
