intake cam bad our good
I have an 05 kx250f and I am wondering if their is a way to tell if my intake cam is bad. I think the sprocket turned on the cam just a little. Is the hole on the lobe supposed to line up with the hole in the sprocket when you look down it. mine is about 2 teeth off. the exhaust cam holes do line up. do I have a bad intake cam?
hard to say with out a picture. even then its hard to say with out realy looking at it.
all my cams are tigwelded to prevent this from happening.
Yes, the 2 holes should align.
Press the sprocket off, press back on in correct position and TIG weld 2 small spots to keep it from turning again.
