Dyno jet question
07 sm
1000ft elevation
3x3 mod
Fmf power bomb - Q4 muffler
needle-2nd grove from top
main jet 155 ????
mixture screw ???
K&N filter
fuel screw around 2.5 turns out,comfirm your pilot circut to be sure http://www.thumpertalk.com/forum/showthread.php?t=327405 155mj will be good maybe a tiny bit rich but to know for sure you need to put your bike on a dyno with an afr readout.the other way to check is to pull your airbox cover off and test it like that.if it pulls better at wot with a 155mj and the airbox door off then your rich
