RM 250 jetting (Again)
Hi,
Need some advice from the jetting people on here.
My 08 RM250 runs really rich at very low throttle openings.
Imagine high speed top gear on a flat road. Throttle just open slightly so you get a nice steady cruise, hardly any load on the motor.
It will crackle and splutter and spooge starts to form at the silencer outlet.
I have been playing with the jetting and found several ways which seem to improve this....
1. Increase the straight diameter of the needle (This sometimes gives me a high hanging idle for a short time after stopping)
2. Raise the clip position (This makes the bike vicious through the midrange and like an on/off switch power delivery)
3. Needle back to standard in standard position but reduce pilot down to 40 (it also takes a 35, Bear in mind the uk standard needle is 2 steps richer on OD and 1/2 clip richer than your NECJ) Power is smooth through the midrange
What do you think would be the best way to achieve what I want?
I like how it rides using the small pilot setup but I'm worried it's too small (everyone else seems to use 45 or 48)
Thanks
OK I will give that another try :)
Can I ask why you think that is the best way to do it?
Thanks
I think that the current needle is too rich.Once you get closer to the US stock settings it should be better and allow you to open up your jets a bit more. Also check your float level. If you need to know more about jetting, click on the Suzuki FAQ's sticky.
