Cycra probend mount problem
I bought a set of Cycra probend hand guards with the u-clamp mount. On my 04crf450r (oem: bars, clamps). I am having issues since the u-clamp does not even come close to the aluminum bar to mount. Also the u-clamps wont fit around the bars, since they hit the top of the fork tubes and push into the number plate. Has anyone else had any issues mounting these guards before?
here is the link to the guards I have. http://store.cycraracing.com/prrapawiumo.html
yhst-2483094475615_2041_13373906
Ive always bought the triple clamp mounts and never had any problems. I never liked the bar mounts for that very reason, they never seem to fit right and can turn when you crash.
I am running the triple clamp mounts as well on the Cycra Pro Bends.
I have been messing around with these for a few hours and seem to think it might be my bar width (29"). I have mounted them with the u-clamps and looks if they were to work it would need 3" more bar per side, making a total of 35" wide. That seem way wide for any bars.
It seems to me that you cut your bars about an inch too much. What I have done in the past is mount the clamps on the bars where you can without interfering with anything else, then mount the guards and mark where the mounts are, drill a new bolt hole and bolt them up. The triple clamp mounts come with 2 holes to help with this.
I also had a problem with the fit of the probends and triple clamp mounts, with the front break caliper and cables. I sent them back and got the PROBEND CRM'S racer pack. These guards fit up great and are very strong.:)
Here a link to them. http://store.cycraracing.com/ceremo7ba.html
Stewart Frank
09CRF450R
STORM#350
