08 TE610 shock HELP!!!!
I was goofing with the shock adjustments- the tiny set screw on the high speed comp. adjuster dial, what is it for? thought I needed to loosen it to adjust HS comp. and while trying a very small amount or oil seeped out :) Did i break something?
It's a set screw to hold the knob on. Loosen it push the knob back on and tighten it. You should be fine. Later George
