no bottom or mid after quiet core insert
I have an o1 yz426 with a powercore 4. I recently installed a quietcore insert. Now i have no bottom end or mid range. After talking to the bike shop they suggested i drop down on the main jet from a 162 to 158.
It still runs the same. Any other advise would be helpful thanks.
Main only affects WOT. Do not take that shops advice again, they are clueless. But... with the insert, you do need to run a smaller main, so they were correct bt accident.
Move the needle clip closer to the top/flat. Try two positions closer. This will lean the mid range some.
