Keihin idle screw help
I have a 99 CR250 with the stock Keihin carb. Have a JD jet kit and it runs great.
My problem is the idle screw. Its made of plastic. The idle never stays the same. I can turn the screw in and the idle will go up and then come back down.
Does anyone make a idle screw that is not made of plastic. I think the end of the plastic screw has a flat spot on it now, but I don't want to buy a OEM screw and have it do the same thing. Thanks Guys!!
