rebound adjuster not bottoming
Hi I'm new and from england........don't hold this against me!!
Anyhow tried to set the suspension on a 06 525 and the rebound screw just turns and turns so i don't know if it is doing anything or not or where 22 turns out is as i usually start at standard setting and work form there.
I've had loads of KTM s and never come across this before.
Any advice much apprieciated
Cheers D
Unscrew the fork cap and check:
pin of the rebound adjuster is broken or it is too far out.
Sorry, I'm been unspecific, it's the rear shock I've go a problem with
The adjuster is broken.
You will need to have the shock serviced.
or, if you're talking 'bout the shock: :banghead:
