Oil screen
I purchased a used 07 yz250f. When I went to change the oil I followed all the directions in the manual but I could not find the oil screen. I took out the screws where it was supposed to be but no screen. My question is where the heck is it? Do some people take the screens out? What should I do? Thank you.
its under the oil tank when you pull out that bottom bolt
it should be there
if not, replace it
did u get it used?
If you remove the fitting the drain bolt goes into the screen should be soldered to the end that is in the oil tank. I pulled mine out on the first oil change as the manual recommended. it was perfectly clean and a pain to get out without damaging. I plan on only checking once a year.
good luck.
