2002 XR100R Oil leak
Ok i've got oil leaking from behind my alternator. My best guess is that the crank oil seal and o-ring are bad and need to be replaced. Anyone out there done this before and can give me some incite on the do's and don'ts of this fix i'd appreciate it. I don't have a manuel, but i'm sure some kind fellow out there would look this up for me and give me some instructions on how to go about fixing this without tearing something up. Thanks in advance!
You need Motionpro flywheel puller for the flywheel and a impact driver for the screws. Just grease up the seal when you put it in. I use a big washer and I tap it with a rubber mallet. It's a pretty straight forward job. But you should always have a manual to reference pictures or procedures.
