TM 2t big end play
Hello Thumpertalk
I bought a TM250 2t enduro, year 2000, lovely bike, until.....
....I removed the cylinder to fit a new set of piston rings and found the conrod play to be bigger than other 2 stokes I have owned-
Conrod side to side play - 0.8 to 0.9mm
Conrod vertical play - 0.1mm (hard to measure, sense of feel)
Mains are perfect, no play when I checked the bike out when I bought it.
No manual to check for wear limits. Any advice welcome
Steve
Hey Steve, this motor uses a "honda CR250" spec rod kit and main bearings, so I would rely on measurements applicable to the 2000 CR 250, which are easily available anywhere...
