cr250 compression
I just rebiult my motor and pressure check it even before I seated the rings and it was at 200psi:thumbsup:
Whats the history of the bike? 205psi sounds like it could have had some work done to the head, unless theres just some variation in your compression tester, which can happen often, plus or minus 10% is about as good as many of the cheaper ones get.
Id be looking at running something a little better than pump fuel with 205psi.
