08 250 boggs and pops and shut off help
my friend has a 08 250 that keeps messing up. when its cold it runs and idles fine when it gets hot and you go from no to little throttle to full throttle and it will bog and pop and stalls the engine out somtimes. this happens while riding it or just bliping the throttle sitting still. has anyone had this kind of issues with these bike. any help would be great thanks
Might want to check that the hot start cable didn't get pulled out from the carb...
ours did the same,unless the choke was on it would bog and just die,its real cold out here but we went to 2 1/2 on the mixture screw and it helped,pretty much has to be real warm before you even move it.were at 7 hrs on it now and its alot better now.guess needs to be broken in for a bit.
thanks for the help i ride andknow 2 strokes so i havent had much time to mess with fcr's and four strokes much so was just looking for some direction.
