Carb leaking YZ125 help!!
I have a 1994 YZ125 that just likes to piss out the gas when I turn the gas on once its running it stops but before I start it it just leaks like crazy I have cleaned it out completely any sugguestions?
your float needle and seat are worn out , lota vibration over the years !
I just replaced those on our 03 yz125 , all is well now.
First , you can get OEM yam stuff easy right here at TTalk . My float valve was $20+-
This is a great oppertunity to clean out all the goobers and crud outa your carb bowl anyway. You will be surprised on whats been hiding in there
Install . best way is to have the carb tottaly off. So the gas tank,seat have to go. also take the muffer off so you can hinge the rear sub frame down.
Loosen the carb bands , pry the carb out .
Take the carb bowl off , remove the float . Now you have access to the needle and its brass seat.
Its not that bad , in about 1.5 hrs you'll have a clean jets, clean bowl and a bike that runs better and does'nt pee near as much.
24hrsparkey
