04 WR250F stock 13 /52 gearing
My stock gearing to to low in Frist and to high in 3rd to let the motor work in it's torque band at the speed I ride in tight single track.
My goal is to have it work harder in 2nd.
Has anyone try'ed a 12 /52 set up?
If so, will I be OK with the stock 520 chain length?
I ran the 12/52 combo for 4 years without any problem. You can use the stock chain length, no worries.
AV, Thank You. Did this combo take a lot of top speed out?
Probably lost about 7-10 mph but the low-end snap is what I was looking for along with a lower 2nd gear. It still topped out at around 75 mph or so - way too fast for the woods anyway... You'll only miss your top speed on wide open roads. At 75 mph it was still faster than the stock YZFs.
I'm glad to hear that. I just picked up a 12 and will check it out this weekend. Also do more wooded type riding and found the stock setup abit high.
I just changed my 04 WR250F to 12/52. It definitely gives the low-end gearing you're looking for. I have tried it twice out on the dunes. I can now ride the whoops and most of the dunes in 3rd and 4th, instead of 2nd and 3rd with an occasional 4th.
However, something to think about: I was looking here on thumbertalk and came across a thread that stated a smaller front puts more stress on the rear suspension. The thread suggested increasing the back when and/or where possible.
I am staying with my 12/52 as it is the gearing I'm looking for when riding technical single track.
Hope this helps.
