How do you empty the bowl?
from what ive read you can just leave it in the on position and it will be like holding your finger on a staw full of liquid (it wont flow out).
my SM has a screw on the bottom of the bowl to drain it. hope this helps!
Assuming you have the vacuum petcock with positions "on", "prime", and "res". The petcock will not flow gas in the "on" position without a vacuum being pulled by the engine. therefore when the bike is not running(no vacuum) "on" is equivalent to off.
Jbw
The petcock is vacuum operated. With the engine off the petcock turns off in the run and reserve positions. The prime position is always on.
