2003 Yz250f Wont Start
I was riding yesterday and out of no where it bogged down and died. It wont kick start, and when i try to push start it, it will bogg a little bit but only if i hold the throttle wide open. But still it only boggs for a couple seconds then dies again? I took the carb apart and it was fine, also replaced the spark plug but no luck.... Any suggestion before i take it to the dealership and pay a butt load?
What do you mean the carb was fine? It looked fine or you removed all of the jets and cleaned it with (o ring safe) carb cleaner and an air compressor?
What did the old plug look like?
Have you checked to make sure your valves are in spec?
Is the chock and hot start working correctly?
