Oil Leak, Help!!!
I have an 06 RMZ250 with a problem... Oil is shooting out of the side of the head where the valve cover meets the tub. There are no cracks in the valve cover or tub and I just replaced the gasket but it is still leaking... :) Has anyone else had this problem? and what can I do to try and fix it?
I am having the same problem on my 07 RMZ 450 I will let you know if I figure anything out.
I have a 2006 kx250f and I am having a similar problem. I havent changed the gasket yet, but plan to soon. Let me know if you figure out the cause of the problem
You are supposed to use some gasket cement like Yamabond at 4 points on the rubber gasket. Check your owners manual!
I put some formaseal on the rubber gasket, let it set overnight and when I rode it started spewing everywhere again... going back to leg power... if you guys figure anything out, post it up. thanks.
So I put ultra blue RTV sealant on the front top side ( cam chain side) of my head just a thin layer going all the way around the coners and Cam "U's" Let it sit for a few hours started bike and got rid of the leak. I will update if it comes back. I spent $6.00 total. Worked like a champ!! :thumbsup:
