82-83 suzuki sp125 timing marks
if you look in one of these service manuals it says set the timing at top dead center on the compression stroke, line up the "t" line in the middle of the inspection window on stator cover. are they referring to the scribed line next to the letter t or do you line up the letter t in the opening and the horizontal line on the camshaft should be parallel with the cylinder head. can any one verify this , because i'm having a hard time starting the bike. fuel part is ok
