not running right
guys, i have a 05 kxf250 and the thing does not like idling, i am going to strip the carb and rebuild it, so i need your help...
  • can i buy a service kit for the carb
    what are the standard settings i.e. needle height
    how do i check the float height
    is there any better settings than std
    is there a rough position of the adjuster screws
thanks in advance for your help.
the only thing thats hard IMO is the float height, it's hard to hold it in the perfect to position and then try to measure it with the other hand....
But unless it's stuck it shouldnt be out of adjustment, just check the little rubber tip as they do deteriorate over time.
The kets and the needle are easy as can be
the link is good and many thanks but it doesn't give you the needle height.
can anyone advise on this and also the mixture screw, how many turns as a rule of thumb?
I don´t remember the -05 spec regarding the needle, but if it´s the stock needle the clip is usually in the middle position.
The fuel screw does not have a "definitive" setting, it changes with the weather. Set it at 2 turns out from fully seated and go from there.
hey i looked for the team green specs and cant find them, but look in primals sticky, think he's got them there,
http://www.thumpertalk.com/forum/showthread.php?t=644837
and i saw that on mdk's web site they had jetting specs, but only for 08 and 07 right now.
also check out mwagner01's sticky about carb cleaning.
http://www.thumpertalk.com/forum/showthread.php?t=706330
ha didn't even see you posted the carb cleaning already D-K
Hehe, I didn´t say it...:)
didnt mwagner post a thread about it? where is he?
Great help guys, i took the bike out on thursday for a charity day but i didn'yt have chance to do the carb before that so i had to turn the idle up to get me ovr the problem.
i shall be stripping the carb this weekend, with the laptop in the garage with me so i can follow it step by step.
thanks again
