Beta 450 Clutch Problem
Took a couple of riders out on the weekend ( KTM530 2008 and a Yam Quad )....cut a long story, it was quite an easy day BUT i noticed my clutch lever was loosing its pressure and by the end of day , I could pull lever right back to bars and the clutch would not disengage....
Now there is little pressure to pull lever....I suspect a leak in the hydralic system......Is the clutch system Magura ( same as KTM)??
Anyone help as I'm supposed to be riding again this weekend....
Cheers
Max
I've had my clutchlever adjustment screw back out on me a few times.... but no loss of hydrolic fluid.
Round by where the pin goes into the cylinder, it looks wet so I'm thinking there is a leak.....Apparently you can by a seal kit...
Will update shortly..
