SM rear wheel wobble
I just mounted SM wheels on my S for the first time today and when I took it for a test ride it felt as if the rear wheel was warped. I checked it and everything is straight. I held the wheel at opposite ends and did a push pull test and noticed that some spokes are loose. Is this something that I can do easily?
Is the wheel aligned properly? "Looked straight"? Did you try spinning the wheel holding a pen/pencil/straw close to the rim and see if it is actually warped? How loose were the spokes? How many were loose?
Here's some info that might be useful to you. It's from the wheel/tire section of the tech tips here...http://www.thumpertalk.com/forum/forumdisplay.php?s=&daysprune=-1&f=396 It's not too hard if you just take your time and do it. I've done a few and you learn pretty quick. Good luck...:)
Thanks. I found some loose ones and just snugged them up. I then tapped the spoke to see if it was roughly the same tone as a tight one. The wobble has gone away and there is no warping. Some spokes required 2-3 turns!
I will be taking it to someone who knows what they are doing because there are some that seem to be stuck.
A little wd-40 will loosen those up. If you do take it somewhere, try and watch what they do, it'll save you some money in the long run....:)
Ok,so if I tighten up the loosies until they make a ping then i should be ok? What if i over tighten one a little too much? My thinking is that if I just tighten them it may cause the wheel to be slightly ovalish causing a flat spot type of ride. That is why i was thinking of taking it to a pro with a torque wrench. Don't know what to do:banghead:
I don't use a torque wrench b/c I don't think it's needed and I ain't paying that much for one. I used a small adjustable and went around the wheel a number of times til it was all done. I learned by doing it and feel comfy enough to do my own but if you don't feel confident then take it somewhere. It's better to pay a few bucks and get it done right than to worry everytime you throw your leg over the bike.....:)
