how do i remove this bearing?
the bearing that is on the clutch disengaugement shaft side inside the motor
the bearing in the middle
pic ?? If its the one I'm thinking off you nee and internal puller to get it out.
MM
yeah, cant really picture it off the top of my head. but if it is in something aluminum, toss it in the oven for a little while and the bearing will fall out
he is talking about the clutch arm that goes into the motor right below the carb and above the front sprocket , may i ask why you want to replace it?it just a roller bearing and i highly doubt its bad
MM
Yes that one requires a internal puller. I had to replace that one on a bike once and I just took it into the local dealer and they pulled it for like $20.00. :) As posted above though this bearing rarely goes bad.
