07 WR250 Chain
I was somewhat disappointed to see that the chain on my 07 WR 250, does not have a master link. I already have an old chain breaker, and if it's not up to the job, a hand held grinder will be. Evidently using a link to reconnect the chain would require a press and riveter? In the past I have used vise grips with a small nut to press the plate over the pin, but the very little amount of riveting I have done involved a ball peen hammer. I don't care to spend $50-60 on tools that I won't need often. The chain is an O ring, 520 I'm assuming, but pin size and width might not be common. Anyone run into this and if so what have you done? Thanks Ron
