Missing O Ring
Want oil bypassing the filter?
If the dealer doesn't have it in stock you can get a filter from NAPA auto parts. It comes with the gaskets. Part number PS7931
How does it bypass the filter w/o the little o ring?
Isn't there enough pressure w/ the spring/nuts?
I seem to remember 13 X 2mm. Almost any size that fits over the boss will do. 9/16 X 3/32 (2-113) is close. Available at many auto parts and hardware stores. And yes it is necessary to assure oil goes thru the filter.
The little o-ring is there to seal the filter to the housing. Without that seal a small amount of the oil will move between the filter and the case instead of going through the filter. I'd rather all the oil went through the filter.
Totally makes sense...thanks guys...will add o ring asap.
