fcr question
I just purchased an old style(slant) fcr and was wondering if the parts needed for the conversion are the same as for the new style? And are all these suzuki part #s ? And finally can anybody recommend jetting set up for riding between 7000-9000ft. Bike is stock except for 3x3 mod.
021-216 FCR Adapter 2 3/8", carb to S airboot
- 021-439 Adaptor O-Ring
- 017-262 EMN Needle
- 021-012 Airboot adapter bolts (2)
- P/N 13111-29F00 OEM Suzuki E Intake Manifold
- P/N 09402-58208 OEM Suzuki Clamp
- P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple
Boy am I glad that someone else asked this question! I have been using the search to avoid:bonk:
You will need the E throttle cable as well.
Any fitment issues with this carb? Is it a bitch to install? And one final FCR question. Can anyone recommend jetting at sea level with just the 3x3 mod?
Thanks!
stock pipe,sea level,3x3
155 main jet
200 main air jet
EMN needle
clip 3
45 pilot jet
100 pilot air jet
2 turns fuel screw
Not with a OEM slant style.... Must use E cables with it
nope,have slant on my sm and stock cable works fine.
155 main jet
200 main air jet
EMN needle
clip 3
45 pilot jet
100 pilot air jet
2 turns fuel screw
Sorry Ed I forgot to ad a mod. I have removed the CE and jumped the nips. Thank you!
Really, I heard the S cables were slightly too long. Is your cable adjuster screw maxed out? Is the cable making contact with the frame?
Yes, you can buy jets separately. Most decent MC shops will have them. Take the old ones in to make sure you get the right style.
