? about wiring
i want to wire in a head light on my 08 450 xcf for street use anyone know if there are wires for that allready on the bike
Easiest way is to use an EXC main wiring harness as it has the connectors to suit the light switch, headlight, rear light, brake light switches etc.
A small amount of work on the regulator connector is required as the XC-F uses a different one to the EXC, but I can talk you through that.
BUT
If all you want is literally a headlight and you are putting your own on/off switch, pick up +12v from the black/white wire on the regulator and use a ring terminal on the coil mount as ground.
